s.in.ascii
rww at ecos.unh.edu rww at ecos.unh.edu
Wed Feb 3 09:04:25 EST 1993
Hello nancy,
If I understand your question, you have a file with
	x | y | z
in them and want
	x # y # z
try the command
	sed 's/|/#/g' infile > outfile
an explanation
	sed is the command
	the ' ' are to isolate the sed command from the shell
	s is the switch command
	/|  is what to search for
	/#  is what to replace with
	/g  tells sed to replace all |'s found on each line not just
		the first one
	infile is you  x | y | z  file
	sed will write to standard output unless it is redirected
let me know if you have any questions
oops I just saw johnson's e-mail with a different approach
why awk when you can sed ???
