vectors
Bruce K. Wylie (303) 490 8336
wylie at gpsrv1.gpsr.colostate.edu
Fri Feb 5 09:50:51 EST 1993
Have you looked at v.patch to combine vectors?
Regards,
Bruce
> I have 5 seperate vector files that I want to combine
into 1. Is there a simple command to do this? The approach
I've taken is to convert them all to ASCII, write a header
with a region large enough to contain all the vectors and
concatenate the points from each file into a single large
file. A problem which arises here is: ...
MAP NAME: MAP
DATE:
MAP SCALE: 6000
OTHER INFO: ZONE: 0
WEST EDGE: 1430.469
EAST EDGE: 2106.561
SOUTH EDGE:-1170.017
NORTH EDGE: -707.333
MAP THRESH: 0
VERTI: what
is this? l 363 < how are these
numbers derived? the first is always a one but the second? ( It
isn't the number of points, I've checked that possibility )
Does anyone know? - many thanks, briann
