v.digit
Bonnie Weller
weller at osiris.cso.uiuc.edu
Wed Feb 10 15:48:55 EST 1993
In info.grass.user you write:
>We are trying to create point maps using v.digit. I've used v.digit
>quite successfully in the past, but am having some odd problems using
>it now. We would like to use Lat/Lon (I am used to UTM), and think this
>is where the problem lies.
>When we register our points for the quad we are using at the time and
>define our region to digitize we get a message regarding scale, like
>the calculated scale is not close to the map scale of 24000. I don't
>know what the calculated scale is because it isn't shown.
>For resolution in both directions we have use 0:00:30.
>I can successfully run v.support, but when I display the quad the coords
>are all off? This may seem cryptic but we can't seem to figure out what
>else to do!
>Can someone help? Our phone number is (916) 551-3392, ask for Tina!
>Thanks
I accidently posted my response to you. Actually I do not have a
solution but a similar problem. Should you get any responses please
forward them to me. If we get any we will forward them to you.
Thanks
Bonnie
