g.help problem
    Bill Brown
    brown at zorro.cecer.army.mil
    Thu Feb 11 09:50:01 EST 1993
Changyi Sun writes:
> We are having a problem with the g.help after we successfully (?) installed
> GRASS 4.0 on our SiliconGraphics IRIS-4D.
This is an old message that was posted in response to the same problem
several months ago:
From: hoffmann at urzdfn.kartographie.tu-dresden.dbp.de
Message-Id:  <930108105358*/S=hoffmann/OU=urzdfn/OU=kartographie/PRMD=TU-DRESDEN/ADMD=DBP/C=DE/@MHS>
Sender: lists-owner at max.cecer.army.mil
Reply-To: grassu-list at max.cecer.army.mil
Precedence: Bulk
Sender: lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
In-Reply-To:  <199301080924.AA21771 at max.cecer.army.mil>
Subject:  (was without subject line: about G.HELP)
Status: R
Try it to use with ^j after command instead of RETURN.
We got the same effect, but on a TEK-88(U/TekV).
Example:
GRASS> G.HELP^J     (control/j)
It should be an effect of unix compiling... our gurus said.
FH-TUD
