Installing GRASS4.0 on an SGI workstation?
wes at msc.edu wes at msc.edu
Thu Feb 18 15:18:01 EST 1993
[]You probably need a -cckr flag.
Thank you for helping with my compiling problems.  The "-cckr" flag did
indeed take care of many of the compilling errors.  Still, I have had to
edit the GRASS source a bit to remove other errors.  As I continue to
do this, I am wondering if this is typical of the SGI port or if there
is something else I am missing.  For example, here is another error message.
Is this something you have had to deal with too?
GISGEN: imagery/i.class - Thu Feb 18 12:36:08 CST 1993
/work/i1a/GRASS4.0/src/imagery/i.class
  mkdir OBJ
  make -f OBJ/make.rules
        rm -f OBJ/main.o
        cc -O -cckr  -I/work/i1a/GRASS4.0/src/libes -DUSE_TERMIO -c main.c
ccom: Error: ./globals.h, line 28: redeclaration of COLORS
       int COLORS[10];
*** Error code 1
Stop.
GISGEN failure at STEP: imagery/i.class
      o o o o o o o . . .   ________________________________ _____=======_T___
    o      _____           ||Wes Barris                    | | wes at msc.edu   |
  .][__n_n_|DD[  ====|____  |Research Equipment Inc. dba   | |(612) 626-8090 |
 >(________|__|_[___/_____]_|Minnesota_Supercomputer_Center|_|_FAX: 626-1596_|_
 _/oo OOOOOO o`  ooo   ooo  'o^o^o                    o^o^o` 'o^o         o^o`
You have an ambitious nature and may make a name for yourself.
