No subject
Joyce Anne Nagle nagle at hanover-crrel.army.mil
Mon Feb 22 08:08:10 EST 1993
> I am still having problems reading in my dems.  This is the output from the command m.dem.examine. Note the resolution (0)
> MINDEGO HILL,CA  BIG BASIN DEM  DLG-DEM
> min elevation: 224.000000  max elevation: 2816.000000
> ns_res: 0.000000  ew_res: 0.000000
> # of columns in file =   809773872
> file north UTM = 4136628.750000
> file south UTM = 4122665.750000
> file east UTM = 577600.937500
> file west UTM = 566405.250000
> Danimal
  We were having trouble with importing a DEM recently and it turned out
to be the way we were reading the tape and NOT the m.dem.extract command.
Make sure that when you are reading your tape that you are using a
variable record length so that you get the last block that is not always
a full record length.  This took care of our problem.
Joyce A. Nagle
U.S. Army Cold Regions Research and Engineering Laboratory (CRREL)
Remote Sensing and GIS Center        email:  nagle at hanover-crrel.army.mil
72 Lyme Road                         phone:  (603) 646-4161 / 4100
Hanover, NH  03755-1290              fax:    (603) 646-4278
