r.le programs
Andrew Hertz
hertz at geog.psu.edu
Fri Feb 26 15:16:09 EST 1993
Filling the void...
1. Successfully downloaded and uncompressed r.le
2. Successfully built the r.le software (?)
Gmake aborted with errors in r.le.setup - couldn't
find polytocell stuff. I monkeyed around with makefiles
with apparent success, but since messages only appear
to tell you of failures, I'm not sure what generated
success. Among the likely candidates, I believe that
switching to the r.le.setup and polytocell
subdirectories and running Gmake explicitly from there
resolved the build difficulties.
I then reran Gmake from the UW directory and everything
else built smoothly.
3. Printed the WordPerfect documentation and postscript
figures and everything appears to be there (55 pages)
except the Appendix 3 Help Menus page is just a title...
4. Superficially executed several routines, particularly
r.le.setup, but since I don't yet understand the metrics
I'm unable to evaluate any results. But the routines
do execute.
Running GRASS 4.0 on a SPARC 2 under OpenWindow version 3.
Andrew Hertz
