problem with r.water.fea
xavier at catap.uab.es
Mon Feb 22 11:21:14 EST 1993
Hello.
I'm trying to compile r.water.fea in an IBM/Risc6000 where is installed
Grass4.1. In order to do it I placed the source code of this program
under "$GISBASE/source/Incoming/R.water". There, I typed "gmake4.1
./src". There apearred to be no problem during the compiling process.
The compilation did not create anything in the directory "$GISBASE/bin".
Instead, in "$GISBASE/etc" was built a new directory called "r.fea". It
contained six executable files called: "cfeapro.bd", "datafea", "feapro.bd",
"querydata", "select_basins" and "show.sh". I made a cat of all them in
different orders. With no of them I was able to run r.water.fea as I expected
after having read the tutorial.
The main problem I have trying to run these files are the next:
In "cfeapro.bd", when it asks for a slope raster map name it always crashes and
writes "Fatal error - File opening".
"feapro.bd", after asking the same as before only accepts slope files of an
unknown (at least for me) slope files list.
I feel I'm missing something.
What is it??
Thanks in advance.
Xavier Ros
Dept. de Geologia
U. Geodinamica Externa i Hidrogeologia
Universitat Autonoma Barcelona
e-mail: xavier at catap.uab.es
