Digitizer Question
Stuart Bradshaw
lewis!bradshaw at cerl.cecer.army.mil
Tue Jan 12 13:02:08 EST 1993
I've seen this message before, but never got as far as digitizing when this
message occurred because the problem was, the computer wasn't talking to
the digitizer (getting a response). In our case it was a matter of getting
the settings on the digitizer correct (parity, stop/start bits, etc). So maybe
something like this needs to be adjusted.
P.S. you should put your e-mail address in your signature block.
Stuart Bradshaw
> When we go into v.digit and try to register the map we get the following error messages:
> HOLD: Digitizer is out of sync
> Trying to recover
> Recovered
> Continue
> The digitizer seems to accept the points and will allow you to digitize, however
> the error messages make this damn near impossible.
> _________________________________________________________________
> | Scott Walker |
> | U.S. Army, Corps of Engineers |
> | Fort Worth District |
> | CESWF-PL-RE |
> | PO Box 17300 |
> | Fort Worth, TX 76102-0300 |
> | ph (817) 334-3246 |
> | fax (817) 885-7539 |
> |_______________________________________________________________|
