Altek AC31 config script!!
Malcolm Williamson
malcolm at cast.uark.edu
Thu Jul 8 11:37:57 EDT 1993
Here is a script that may help some of you other Altek users. Instead of having
to manually set the dip switches, you can simply run this script to configure
the digitizer. Ravi Kiran, one of our system administrators, wrote this in
order to enable us to easily switch from digitizing in GRASS to ArcInfo to PCI.
It can easily be edited to suit your needs.
config_altek
#!/bin/sh
#Program : To configure Altek Digitizer AC31
#confirm if this is the port being used for the digitiser
echo ""
echo " Digitizer Setup"
echo ""
echo " Program assumes serial port used is \"/dev/ttya\" "
echo -n " Is this correct ? (y/n) [y] "
read answer
#If default answer then serial port is ttya
if [ "$answer" = "" ] || [ "$answer" = y ]
then
echo ""
ser_port="/dev/ttya"
echo " Serial port is $ser_port"
echo ""
else
echo ""
ser_port="/dev/ttyb"
echo ""
fi
echo " Enter the Application Number :"
echo ""
echo " 1. PCI"
echo " 2. Grass"
echo " 3. Arc-Info"
echo ""
echo -n " Enter Choice [2] "
read appnum
case $appnum in
1) echo ""
echo " PCI Mode selected for digitizer"
echo \033 > $ser_port #Reset controller first
#PCI setting
echo R2 > $ser_port #Rate 2
echo I5 > $ser_port #Increment 5
echo P > $ser_port #Point Mode
echo M1 > $ser_port #Resolution 1
echo F1 > $ser_port #Format 1
echo c1 > $ser_port #Carriage Return on
echo l1 > $ser_port #Linefeed on
echo B1 > $ser_port #Beeper turned on
echo W > $ser_port #Save in NonVolatileRam
echo ""
echo " Initialising done for PCI"
echo "" ;;
2) echo ""
echo " Grass Mode selected for digitizer"
#Grass Setting
echo F8 > $ser_port #Format 8
echo c0 > $ser_port #Carriage Return off
echo ""
echo " Initialising done for Grass"
echo "" ;;
3) echo ""
echo " ARC-INFO Mode selected for digitizer"
echo F10 > $ser_port #Format 10
echo ""
echo " Initialising done for ARC-INFO"
echo "" ;;
[4-9] ) echo " No Mode chosen !!"
echo " Digitizer settings not changed"
echo "" ;;
esac
Malcolm D. Williamson - Research Assistant E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
