Altek AC31 config script
    Malcolm Williamson
    malcolm at cast.uark.edu
    Thu Jul  8 13:17:47 EDT 1993
My apologies for wasted bandwidth. I forgot to mention the initial settings
needed to run the Altek AC31 configuration script that I posted earlier.
		 S1
		0 1
1       dipsw     x  NOVRAM
2
3
4
5
6
7
8
After setting S1:1 to NOVRAM, reset the controller, and then run the
configuration script. If you are not currently using ArcInfo or PCI, you
can edit those options out of the script.
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
