LTPlus import ?
    Bill Dailey 490-8324 (303)
    dailey at gpsrv1.gpsr.colostate.edu
    Wed Jul 21 14:46:42 EDT 1993
>Hi LTPlus users,
>I have found a simpler method for importing images in LTPlus. I have made
>a program called pnmtoltp, it is a modification of pnmnoraw, the only
>difference is that pnmtoltp does not write the ppm header to the top of
>the file. You could also strip the header off using the unix cmd tail.
>Since pnmnoraw writes lines of 70 characters, you will have to calculate
>the number lines per scanline as follows: (#columns / 70) + 1.
>This way, importing in GRASS is no longer necessary.
>Ronald Wiemer
>ARCHIS, Amersfoort
>The Netherlands
Ronald Wiemer
Could you put your version of "pnmtoltp" in the incoming directory on moon?
thanks
bill...
 21-JUL-1993 12:45:03
