No subject
Net.Noise owner news at max.cecer.army.mil
Wed Jun 2 10:48:41 EDT 1993
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: importing sun rasterfiles
Message-ID: <C80153.ECu at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9306010336.AA13807 at cerberus.earth.monash.edu.au>
Date: Wed, 2 Jun 1993 14:48:39 GMT
Lines: 22
In <9306010336.AA13807 at cerberus.earth.monash.edu.au> simon at cerberus.earth.monash.edu.au (Simon Cox) writes:
>I just tried to use r.in.sunrast and it complained
>" - this rasterfile format not supported"
>My files are
>"      rasterfile, 3074x1938x8 run-length byte encoded image"
>Is it the run length encoding which is the problem?
>If so, is there any way to convert this *without* going
>all the way to ascii (I think my machine might get indegestion!)
>I'm using grass4.0.
Yes, this is the problem. Can you recreate the images in standard format?
You could use the pbmplus utilities.
Michael Shapiro               shapiro at zorro.cecer.army.mil
U.S. Army CERL                (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
