r.le compilation ?
    Greg Koerper
    greg at towhee.cor2.epa.gov
    Mon Jun 14 14:48:21 EDT 1993
> Hello:
> I'm compiling the r.le programs on a Sun10 (SunOS 4.1.3).  I began by
> initiating "gmake4.1" from the directory containing the r.le programs.
> Everything proceeds smoothly until this message:
>    ~/src.contrib/UW/r.le setup
>    make -f OBJ/make.rules
>    gmake4.1  polytocell
>    sh: gmake4.1:  not found
>    *** Error code 1
>    make: Fatal error: command failed for target 'all'
> Any suggestions?
 My echo of the compilation shows the call to gmake4.1 with a full path:
/files/data/heart/data1/grassdir/home/bin/gmake4.1 polytocell
Check the Gmakefile on r.le.setup.  Apparently $GMAKE is not set properly.
The assignment of GMAKE should be defined in src/CMD/GISGEN.sun4
> Thanks,
> Mike Killion  (killion at ukanvm.bitnet)
> KARS Program
> University of Kansas
> Lawrence, KS  66045
