Problems with v.digit 4.1
Malcolm Williamson
malcolm at cast.uark.edu
Mon Jun 28 14:38:05 EDT 1993
> I recently installed GRASS4.1 on our
> SUN sparc 2 with OpenWindows2.0. When I run
> v.digit, GRASS freezes up after responding 'y'
> to the question "Shall we continue?" such that
> I have to completely logout of the system. I saw
> a message describing a similar problem back in May,
> but I did not see a response in the Archives. Has
> anyone found the solution to this problem yet?
> -- Sharyl Walker
> University of Illinois
> Dept. of Agricultural Engineering
> guernsey at holstein.age.uiuc.edu
We are running v.digit under GRASS4.1 on a SUN IPC and a Sparc 1+. First, be
sure that your digcap file is correctly edited; for running an Altek AC30
digitizer controller from serial port A our digcap looks like this:
Altek:/dev/ttya:al30f8_16:Altek digitizer, model AC30, format 8 (binary)
none:nodig:nofile: Run digit without the digitizer.
Then, edit your /etc/ttytab file to reflect this use:
(lines deleted)
ttya "/usr/etc/getty std.9600" unknown off local secure
(more lines deleted)
I got the same error a few days ago, after the digitizer got plugged into the
wrong serial port, and the ttytab file was not correctly edited.
Good luck!
Malcolm D. Williamson - Research Assistant E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
