image problems and labeling problems
Tom Meixner
tom at hwr.arizona.edu
Mon Jun 28 20:16:58 EDT 1993
Hello,
I have just digitized a map from autocad. I have closed up all the
polygons and I am now trying to label the polygons. This however is not working
When I use v.digit to label the areas I am running into the problem that the
labeling routine will no recognize the lines on the map.
I first define my category and then pick and accept a point but when
I go to pick a boundary line I always get the message no line found.
What am I doing wrong and is there a problem with my original
digitizing.
Second, I need to convert this same map to UTM coordinates.
How would I go about doing this.
thanks,
tom
