No subject
    Net.Noise owner
    news at max.cecer.army.mil
    Wed Jun 30 12:44:46 EDT 1993
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: Sites `n' Stuff
Message-ID: <C9G16J.1nL at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9306220117.AA26271 at cast.uark.edu>
Date: Wed, 30 Jun 1993 16:44:43 GMT
Lines: 39
In <9306220117.AA26271 at cast.uark.edu> dgc at cast.uark.edu (Don Catanzaro) writes:
>Netters,
>	I've been using site files and GRASS for awhile and I've run into a
>couple of questions and comments.  The first is that I'm not to sure how
>g.region sites=name works.  According to the manual, it will
>> Set the current region to the smallest region encompassing all coordinates
>> in the named site_lists file, aligned with the current region.
>The part I'm fuzzy on is the aligned part. It seems as if the final region that
>you get when you run this program changes as your current region changes.  Any
>suggestions ?
Alignment is a raster-ism. The region not only specifes the edges but also
the grid cell size. The grid-cell size implies a grid that runs along the
edges of the cells. Aligning the resulting region to the current region means
that the grid postin and spacing will not be changed. The edges will only
will be reset to the nearest grid line.
>	The second question/comment I have is that I wish to see how my sites
>overlay onto different raster maps, ie what categories are the same coordinates
>Is the only way to do this to convert my site_lists to a raster map or am I
>missing something ?  I could run d.what.rast (or vect) and click on each site
>but I have over 900 sites and that would be slightly tedious, is there a quick
>and dirty way to over come this problem ?
Use r.what: s.out.ascii | r.what
>	Thanks for any help...
>				Don Catanzaro
>				dgc at CAST.uark.edu
>				Dept. of Biological Sciences
>				University of Arkansas
>				Fayetteville, AR  72701
Michael Shapiro               shapiro at zorro.cecer.army.mil
U.S. Army CERL                (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
