floating point | null data in GRASS!
Greg Koerper
greg at towhee.cor2.epa.gov
Fri Mar 12 16:52:31 EST 1993
In answer to William Hargrove's comments:
> GrassHoppers:
> I don't really see the big deal about floating point maps and zero vs
> no data problems. Multiply by 10 times the number of decimals of accuracy
> you need to take care of the first problem. Shift all category values up
> one notch to take care of the other.
It is simple to transform one floating-point variable into integer form. But
it is a data management and quality assurance nightmare to be handling
tens of floating point transformations, both multiplication and division.
If I build a customized research environment, now both I and the end-user
must deal with the mental gymnastics. If we wish to develop diagnostic ratios
of output variables, the confusion expands. And now try sharing these data
with S-PLUS, PCI or PV-WAVE for visualization, etc.
Shifting categories is not a solution, because the variables are continuous
scalars (not categories!), and may range from negative to positive. Thus what
had been -1 is now misinterpreted as zero, and image displays have erroroneous
"null data" holes. I have used this chewing-gum approach in the past, but at
a significant cost of my time and that of the researchers I coordinate with.
For example, if you do these shifts, you now have the overhead of kludging the
legend display, etc.
> IMHO, a much more severe limitation to the current implementations of
> GRASS is the current XDRIVER. The named fifo pipe technique is a kludge at
> best. GRASS needs *real* X-window support, including more than 8 plane
> support.
This is a legitimate concern. But at our lab, floating point and null data
limitations outweigh its importance. The user community needs to weigh in on
the competing priorities.
> The people at CERL are aware of this (and even a little defensive
> about it). All such imporvements take, they are quick to point out, is
> time and money ...
Alas, yes.
Greg Koerper Internet: greg at heart.cor.epa.gov
ManTech Environmental Technology, Inc. UUCP: hplabs!hp-pcd!orstcs!koerper
US EPA Environmental Research Lab
200 SW 35th St., JSB
Corvallis, OR 97333 "The 90s will make the 60s look like the 50s.
(503) 754-4490 Just ask your kids."
fax: (503) 754-4338
