Release 4 of proj
    Andrew Hertz
    hertz at geog.psu.edu
    Thu Mar 18 19:53:34 EST 1993
Hello,
About a week ago there was an announcement regarding release
4 of PROJ.  Should this replace the version under mapgen
in GRASS 4.1 beta?
gmake'ing of mapgen failed...error message follows...
cc -s -o /usr/data3/grass4.0/4.1/sun4/mapgen/bin/plotter -O -I/tmp_mnt/usr/data3/grass4.0/4.1/src/../src.related/mapgen/include -I/tmp_mnt/usr/data3/grass4.0/4.1/src/libes -D_GENVB=\"GRAPHB\" -DGRASS OBJ.sun4/DGRASS.o OBJ.sun4/devlist.o OBJ.sun4/plotter.o /tmp_mnt/usr/data3/grass4.0/4.1/src/../src.related/mapgen/lib/LIB.sun4/libdev.a  /tmp_mnt/usr/data3/grass4.0/4.1/src/../src.related/mapgen/lib/LIB.sun4/libplt.a  /tmp_mnt/usr/data3/grass4.0/4.1/src/../src.related/mapgen/lib/LIB.sun4/libgraph.a /tmp_mnt/usr/data3/grass4.0/4.1/src/libes/LIB.sun4/libdisplay.a /tmp_mnt/usr/data3/grass4.0/4.1/src/libes/LIB.sun4/libraster.a /tmp_mnt/usr/data3/grass4.0/4.1/src/libes/LIB.sun4/libgis.a -lm
ld: /tmp_mnt/usr/data3/grass4.0/4.1/src/../src.related/mapgen/lib/LIB.sun4/libdev.a: No such file or directory
Compilation failed
*** Error code 4
make: Fatal error: Command failed for target `/usr/data3/grass4.0/4.1/sun4/mapgen/bin/plotter'
Current working directory /tmp_mnt/usr/data3/grass4.0/4.1/src.related/mapgen/SCS/plotter
Do I need to set the RANLIB environment variable explicity,
and if so what should it be set to?
Thanks for any help,
Andrew Hertz
