copying colr files
Lars Schylberg larss at fmi.kth.se
Wed Mar 24 05:07:25 EST 1993
Hello Grass users !
For those of you that followed my problems with color files yesterday and
the day before yesterday I will here give you my latest solution to this
problem.  I hope that I have learned my lesson about colr2 files now.
I had overseen some possibilities in yesterdays script so here is a new
version of "cp.colr.sh"
I think this script could be educational how the colr2 files work and also
how g.findfile can be used.  Please tell me if I have missed something !!
I know that this should be sent to grassp instead but since I sent yesterdays
script to grassu I thought it was better to send this to grassu as well.
Lars
Lars Schylberg                          Email: larss at fmi.kth.se
Dept. of Geodesy and Photogrammetry
Royal Institute of Technology (KTH)     Tel.   +46 8 790 86 33
S-100 44  STOCKHOLM, SWEDEN             Fax.   +46 8 790 66 10
#!/bin/sh
#  cp.colr.sh
#  Script to copy one color table from one raster map to another raster map
#  The script checks if there exists a colr2 file in current mapset
#  for the input map and uses this file in that case, since this is the
#  file that is used by d.rast.
#  Copies the colortable to: $LOCATION/colr2/mapset/cellname unless the output
#  map is in the current mapset and there exist no colr file for the output
#  then it is written to $LOCATION/colr/cellname.
#  Read 4.0 Programmers Manual 12.10.3.1 for details about colr2 files
#  Author: Lars Schylberg ( larss at fmi.kth.se )
#          Department of Geodesy and Photogrammetry
#          Royal Inst. of Technolgy
#          Stockholm, Sweden
#  Date: 930324
#  History of changes:
#					Check if GRASS is running
test "$GISRC" || echo "GRASS is not running" || exit 2
#					Evaluate arguments
if [ $# != 2 ]
then
    echo
    echo Usage: `basename $0`
    echo '       input=mapname '
    echo '       output=mapname '
    echo
    exit 1
fi
#  parse input arguments
for i do
	case $i in
		input*)
			INPUT=`echo $i | sed s/input=//` ;;
		in*)
			INPUT=`echo $i | sed s/in=//` ;;
		i*)
			INPUT=`echo $i | sed s/i=//` ;;
		output*)
			OUTPUT=`echo $i | sed s/output=//` ;;
		out*)
			OUTPUT=`echo $i | sed s/out=//` ;;
		o*)
			OUTPUT=`echo $i | sed s/o=//` ;;
			echo ""
			echo "Unrecognized option: $i"
			echo 'Options: input=mapname '
                        echo
			exit 1
	esac
done
#				Check the input arguments
eval `g.findfile element=cell file=$OUTPUT`
if [ ! "$file" ] ; then
   echo "$OUTPUT - cell file not found"
   exit 2
fi
eval `g.findfile element=colr file=$INPUT`
   echo "$INPUT - color file not found"
   exit 2
fi
INFILE=$file
INMAPSET=$mapset
#				Use only the first part of the file
#				name since the file paratmeter requires that
INPUT_NAME=`echo $INPUT | awk -F@ '{ printf "%s\n", $1 }'`
#				Check if the input map has a colr2 file in
#				current mapset. Use this if it exists.
eval `g.findfile element=colr2/$INMAPSET mapset=$MAPSET file=$INPUT_NAME`
if [ "$file" ] ; then
   INFILE=$file
fi
#				Check for existance of colr file and if output
#				file is in current mapset otherwise we can't
#				write to it
OUTPUT_NAME=`echo $OUTPUT | awk -F@ '{ printf "%s\n", $1 }'`
OUTPUT_MAPSET=`echo $OUTPUT | awk -F@ '{ printf "%s\n", $2 }'`
eval `g.findfile element=colr mapset=$OUTPUT_MAPSET file=$OUTPUT_NAME`
if [ ! "$file" -a "$MAPSET" = "$mapset" ] ; then
   OUTFILE=$LOCATION/colr/$OUTPUT_NAME
   SAMEMAPSET=1
else
   OUTFILE=$LOCATION/colr2/$INMAPSET/$OUTPUT
   SAMEMAPSET=0
fi
#				Make sure that output path exists
#				if the output is in another mapset.
if [ ! -d $LOCATION/colr2 -a $SAMEMAPSET -eq 0 ]  ; then
   echo "Creating: $LOCATION/colr2"
   mkdir $LOCATION/colr2
fi
if [ ! -d $LOCATION/colr2/$INMAPSET -a $SAMEMAPSET -eq 0 ]  ; then
   echo "Creating: $LOCATION/colr2/$INMAPSET"
   mkdir $LOCATION/colr2/$INMAPSET
fi
#				Copy the color file
cp $INFILE $OUTFILE
