No subject
Net.Noise owner news at max.cecer.army.mil
Fri Mar 26 01:35:16 EST 1993
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: xgrass on DECstation? (strdup undefined)
Message-ID: <C4HGyp.LGq at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <Mailstrom.1.0.61886.11025.nsmith at polar.bowdoin.edu> <9303241850.AA10605 at sonoma.ced.berkeley.edu>
Date: Fri, 26 Mar 1993 06:35:13 GMT
Lines: 84
>> Seeing xgrass in Reston was enough to convince me it was
>> time to make it.  I made grass4.1beta without any problems,
>> but am stuck on xgrass at xgrass/display :  the loader
>> can't find strdup.  Sure enough, it's called in lex.c
>> (and declared twice!), and not defined in any of the code
>> in src/xgrass/display.
>> Have I missed a header file somewhere?
>> I'm compiling on a DECStation 5000, X with Motif;  the
>> X headers seem to be in order.
>strdup is one of the string functions defined under SunOS, among
>others.  But, it is not available for Ultrix, for reasons that are
>unclear to all but DEC.
You could use G_store() from the GRASS $(GISLIB) which does
a strdup() (except ti calls exit() if malloc() fails). Or write
a strdup():
	char *strdup(s) char *s;
		char *b;
		char *malloc();
		if(b = malloc(strlen(s)+1))
			strcpy (b, s);
		return b;
>STRING(3)              C LIBRARY FUNCTIONS              STRING(3)
>NAME
>     strcat,  strncat,  strdup,  strcmp,   strncmp,   strcasecmp,
>     strncasecmp,   strcpy,  strncpy,  strlen,  strchr,  strrchr,
>     strpbrk, strspn, strcspn, strstr, strtok,  index,  rindex  -
>     string operations
>SYNOPSIS
>     #include <string.h>
>     char *strdup(s1)
>     char *s1;
>DESCRIPTION
>     These functions operate on null-terminated strings.  They do
>     not check for overflow of any receiving string.
>     strdup() returns a pointer to a new string which is a dupli-
>     cate  of the string pointed to by s1.  The space for the new
>     string is obtained using malloc(3V).  If the new string can-
>     not be created, a NULL pointer is returned.
>I have fiddled around a bit, trying to get around this, but havn't had any
>luck getting the resulting code to run.  I don't think this one will be too
>hard to fix.
>| Kenn Gardels                Tel +01 (510) 642-9205   Fax +01 (510) 643-5571  |
>| CEDR - 390 Wurster Hall     Internet  gardels at ced.berkeley.edu               |
>| University of California    Bitnet    gardels at UCBCED                         |
>| Berkeley, CA  94720         Calendar  gardels at tahoe.ced.berkeley.edu         |
Michael Shapiro U.S. Army CERL
Environmental Division
