src.contrib problems...
Andrew Hertz
hertz at geog.psu.edu
Sat Mar 27 01:43:51 EST 1993
Hello,
Problems building SCS stuff in src.contrib:
/usr/local/grass4.1/src.contrib/SCS/imp_exp/dig_dlg
make -f OBJ.sun4/make.rules
cp /usr/local/grass4.1/src/../src.related/mapgen/proj/SetProj.c SetProj.c
cp /usr/local/grass4.1/src/../src.related/mapgen/proj/projects.h projects.h
rm -f OBJ.sun4/SetProj.o
cc -O -DUSE_SETREUID -DUSE_SETEUID -DUSE_SETPRIORITY -I/usr/local/grass4.1/src/mapdev/Vlib -I/usr/local/grass4.1/src/mapdev/diglib -I/usr/local/grass4.1/src/include -c SetProj.c
mv SetProj.o OBJ.sun4/SetProj.o
cc -s -o /usr/local/grass4.1/sun4/etc/bin/contrib/cmd/v.out.dlg.scs OBJ.sun4/v.exp_dlg.o OBJ.sun4/area_one.o OBJ.sun4/get_label.o OBJ.sun4/shuffle_dots.o OBJ.sun4/struct_swap.o OBJ.sun4/write_lines.o OBJ.sun4/write_areas.o OBJ.sun4/write_nodes.o OBJ.sun4/write_head.o OBJ.sun4/write.o OBJ.sun4/SetProj.o /usr/local/grass4.1/src/libes/LIB.sun4/libgis.a /usr/local/grass4.1/src/libes/LIB.sun4/libvect.a /usr/local/grass4.1/src/libes/LIB.sun4/libdig2.a /usr/local/grass4.1/src/../src.related/mapgen/lib/LIB.sun4/libproj.a /usr/local/grass4.1/src/../src.related/mapgen/lib/LIB.sun4/libsupp.a /usr/local/grass4.1/src/libes/LIB.sun4/libvect.a /usr/local/grass4.1/src/libes/LIB.sun4/libdig2.a /usr/local/grass4.1/src/libes/LIB.sun4/libgis.a -lm
ld: Undefined symbol
_ABS
Compilation failed
*** Error code 2
make: Fatal error: Command failed for target `/usr/local/grass4.1/sun4/etc/bin/contrib/cmd/v.out.dlg.scs'
Current working directory /usr/local/grass4.1/src.contrib/SCS/imp_exp/dig_dlg
*** Error code 1
Thanks again for any help,
Andrew Hertz
