Compliling r.water.fea
xavier at catap.uab.es xavier at catap.uab.es
Mon Mar 29 07:28:58 EST 1993
Nalneesh,
Many thanks for your answer, but my problem isn't solved yet.
Nalneesh Gaur wrote: "All you had to do was to type r.water.fea and things
would have kicked off from there"
But when I type r.water.fea, the only answer I get is "Not found". Because
the file r.water.fea is not created in $GISBASE/bin after compilation. My
question is why the only file created after compilation is in $GISBASE/etc.
	        			 Xavier Ros
                                Dept. de Geologia
                                U. Geodinamica Externa i Hidrogeologia
				Universitat Autonoma Barcelona
