tek4696 plotter
CAREY at KGS.MM.UKY.EDU CAREY at KGS.MM.UKY.EDU
Mon May 3 12:19:00 EDT 1993
Help! We are plotting using p.map on a TEK4696 (identical to 4695).
The line of the default header box always runs through the top of the
map. Is there any way to fix this?  CAREY at kgs.mm.uky.edu
