mapgen compilation troubles
    Gerald I. Evenden
    gie at charon.er.usgs.gov
    Wed May  5 10:58:55 EDT 1993
> >I believe the problem is in the make file:  that it's trying
> >to compile an include file... message follows...
> >make: Fatal error: Don't know how to make target `/grass.src/4.1/src.related/mapgen/include/graphics.h'
> >Thanks again
> >Andrew Hertz
> >hertz at geog.psu.edu
> Hmm!  Seems to me I've heard this problem before.
> What is going to have to be done is find the Makefile that is blowing.
> Probably in under */mapgen somewhere, depending if you've got release 3
> or release 4.  Now somewhere there is a directory called graphics for
> the mapgen stuff and under that directory there should be a header
> file graphics.h.  That's the one you want to be easily available to
> the Makefile under */mapgen.  Above releases refer to mapgen release
> codes.
> Granted, damn confusing.
> As and alternative, you could grab the mapgen stuff from charon.er.usgs.gov
> and do it's install.  At least I know where everything is there.  But I
> don't know if there are not some program renamings under GRASS.
> I'm going to put this response on grassu to see if I can shake CERLs
> chain to fix this problem.
Does someone responsible for putting mapgen into GRASS distribution have
a more appropriate solution.  I keep seeing this message over and over.
Gerald (Jerry) I. Evenden   Internet: gie at charon.er.usgs.gov
voice: (508)563-6766          Postal: P.O. Box 1027
  fax: (508)457-2310                  N.Falmouth, MA 02556-1027
