Calculating downstream concentration
Charles Ehlschlaeger chuck at ortelius.GEOG.UCSB.EDU
Fri May 14 00:05:55 EDT 1993
David,
Here is a kludgy way to calculate downstream concentrations of chlorides:
You need a map of chloride discharge and a map of rainfall runoff and other
surface water inputs to the map.
Run r.watershed twice, using each of the above maps for the overland flow
option. Each run should give you a accumulation map: one for total streamflow
and one for concentration of chlorides. Use r.mapcalc to divide chloride conc.
by streamflow.
Chuck Ehlschlaeger
