r.poly - v.support warnings
Agustin Lobo
agust at pac0.Princeton.EDU
Tue May 18 09:46:17 EDT 1993
> From grass-lists-owner at max.cecer.army.mil Tue May 18 04:19:14 1993
> From: martijn at scanner.frw.uva.nl
> Subject: Re: r.poly - v.support warnings
> Sender: lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> Date: Tue, 18 May 1993 11:03:33 +0100 (DFT)
> X-Mailer: ELM [version 2.4 PL20]
> Content-Type> : > text>
> Content-Length: 674
> iThis particular warning has no consequences for you. It means that
grass
> finds two identical labels for one area, so only one (the last one
mentioned)
> is kept attached to the area. To avoid these messages, try v.clean
and/or
> v.digit (Remember where it says "Do you want to compress the atts
file?",
> answers Yes).
> Martijn van Leusen
> > Thanks
> > Agus.
Why does grass find two identical labels for one area if my vector
comes from an r.poly on a raster file resulting from r.clump? Is this a
bug?
Agus
