Delivery status: Re: Digitizer thru X-terminal???
-MaiSer-
-MaiSer-.DCRP at mhs.unc.edu
Thu May 27 04:36:00 EDT 1993
A delivery problem was encountered with your message:
Error 101: Unknown user at destination host
Recipient address(es) in error:
ACHET.DCRP at mhs.unc.edu
---- Original text of message follows:
> > Question: Can a digitizer be made to function through an X-Window
> > display server runing on a PC ?
> > Thanks.
> > Bill Miller
I am also very interested in learning whether this can be done. It
would mean less pressure on the workstations that our GIS are
running on (Grass and Genamap), more terminal time available to
staff and students doing the more intensive analytical work.
----\_\_\_--\_----\_------\_-------------------- P. Martijn van Leusen --------
\_ \_ \_\_\_\_ \_ Dept of Pre- and Protohistoric Archaeology
\_\_\_ \_ \_ \_ \_ University of Amsterdam, The Netherlands
\_ \_ \_ \_\_ \_ martijn at scanner.frw.uva.nl
--------\_------\_----\_--\_--\_\_\_\_-----------------------------------------
------------------------- Original message header:
>From grass-lists-owner at max.cecer.army.mil Thu 27 May 1993 04:35
>X-Envelope-To: ACHET.DCRP at mhs.unc.edu
>Return-Path: <grass-lists-owner at max.cecer.army.mil>
>Received: from mento.oit.unc.edu ([152.2.22.70]) by mhs.unc.edu (SMTPSRV); Thu 27 May 1993 04:35
>Received: from max.cecer.army.mil by mento.oit.unc.edu (NeXT-1.0 (From Sendmail 5.52)/TAS/11-16-88)
> id AA19207; Thu, 27 May 93 04:40:59 EDT
>Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA16217
> (5.67a/IDA-1.5 for <ACHET.DCRP at mhs.unc.edu>); Thu, 27 May 1993 03:39:14 -0500
>Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
> id AA23589; Thu, 27 May 93 03:32:59 CDT
>Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA13320
> (5.67a/IDA-1.4.4 for <grassu-people at amber>); Thu, 27 May 1993 03:32:58 -0500
>Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
> id AA23583; Thu, 27 May 93 03:32:56 CDT
>Received: from scanner.frw.uva.nl by max.cecer.army.mil with SMTP id AA16123
> (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Thu, 27 May 1993 03:32:54 -0500
>Received: by scanner.frw.uva.nl (AIX 3.2/UCB 5.64/4.03)
> id AA17318; Thu, 27 May 1993 11:25:40 +0200
>From: martijn at scanner.frw.uva.nl
>Message-Id: <9305270925.AA17318 at scanner.frw.uva.nl>
>Subject: Re: Digitizer thru X-terminal???
>Sender: lists-owner at max.cecer.army.mil
>Reply-To: grassu-list at max.cecer.army.mil
>Precedence: Bulk
>Date: Thu, 27 May 1993 11:25:40 +0100 (DFT)
>In-Reply-To: <112670010243923EMU0000 at dg4600.swc> from "Bill Miller" at May 26, 93 12:40:00 pm
>X-Mailer: ELM [version 2.4 PL20]
>Content-Type: text
>Content-Length: 787
------------------------- End of message header:
