Delivery status: Re: Please help:r.in.erdas problem
-MaiSer-
-MaiSer-.DCRP at mhs.unc.edu
Thu May 27 09:14:00 EDT 1993
A delivery problem was encountered with your message:
Error 101: Unknown user at destination host
Recipient address(es) in error:
ACHET.DCRP at mhs.unc.edu
---- Original text of message follows:
Hi, r.in.erdas does not seem to recognize the header as you have mentioned. The
workaround is to use r.support and edit the projection and region information
after you have imported the erdas coverage. Good luck.
Prasad
------------------------- Original message header:
>From grass-lists-owner at max.cecer.army.mil Thu 27 May 1993 09:11
>X-Envelope-To: ACHET.DCRP at mhs.unc.edu
>Return-Path: <grass-lists-owner at max.cecer.army.mil>
>Received: from mento.oit.unc.edu ([152.2.22.70]) by mhs.unc.edu (SMTPSRV); Thu 27 May 1993 09:11
>Received: from max.cecer.army.mil by mento.oit.unc.edu (NeXT-1.0 (From Sendmail 5.52)/TAS/11-16-88)
> id AA20520; Thu, 27 May 93 09:16:55 EDT
>Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA22241
> (5.67a/IDA-1.5 for <ACHET.DCRP at mhs.unc.edu>); Thu, 27 May 1993 08:14:29 -0500
>Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
> id AA26225; Thu, 27 May 93 08:05:51 CDT
>Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA14743
> (5.67a/IDA-1.4.4 for <grassu-people at amber>); Thu, 27 May 1993 08:05:50 -0500
>Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
> id AA26219; Thu, 27 May 93 08:05:47 CDT
>Received: from landcover.inhs.uiuc.edu by max.cecer.army.mil with SMTP id AA22031
> (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Thu, 27 May 1993 08:05:47 -0500
>Received: by landcover.inhs.uiuc.edu id AA09647
> (5.67a/IDA-1.4.4 for grassu-list at max.cecer.army.mil); Thu, 27 May 1993 08:05:40 -0500
>Date: Thu, 27 May 1993 08:05:40 -0500
>From: Anantha Prasad <prasad at landcover.inhs.uiuc.edu>
>Message-Id: <199305271305.AA09647 at landcover.inhs.uiuc.edu>
>Sender: lists-owner at max.cecer.army.mil
>Reply-To: grassu-list at max.cecer.army.mil
>Precedence: Bulk
>Subject: Re: Please help:r.in.erdas problem
------------------------- End of message header:
