Delivery status: Re: Please help:r.in.erdas problem
-MaiSer- -MaiSer-.DCRP at mhs.unc.edu
Thu May 27 09:44:00 EDT 1993
A delivery problem was encountered with your message:
  Error 101: Unknown user at destination host
Recipient address(es) in error:
  ACHET.DCRP at mhs.unc.edu
---- Original text of message follows:
Be aware of the different headers for .lan files
created using ERDAS7.3 from those done with ERDAS7.4
higher. The lastest IMAGINE is using .img.
If you don't care the ERDAS colors, get rid of
the 1st 128B header and find a way to read
the rest. If your file is in BIL, it's not hard
to read them out and use maybe r.in.ascii somethinkg
like this.
--Xin Zhuang
zhuang at acess.digex.com
------------------------- Original message header:
>From grass-lists-owner at max.cecer.army.mil Thu 27 May 1993 09:43
>X-Envelope-To: ACHET.DCRP at mhs.unc.edu
>Return-Path: <grass-lists-owner at max.cecer.army.mil>
>Received: from mento.oit.unc.edu ([152.2.22.70]) by mhs.unc.edu (SMTPSRV); Thu 27 May 1993 09:43
>Received: from max.cecer.army.mil by mento.oit.unc.edu (NeXT-1.0 (From Sendmail 5.52)/TAS/11-16-88)
>	id AA20865; Thu, 27 May 93 09:48:49 EDT
>Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA23234
>  (5.67a/IDA-1.5 for <ACHET.DCRP at mhs.unc.edu>); Thu, 27 May 1993 08:47:35 -0500
>Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
>	id AA26436; Thu, 27 May 93 08:37:59 CDT
>Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA15166
>  (5.67a/IDA-1.4.4 for <grassu-people at amber>); Thu, 27 May 1993 08:37:58 -0500
>Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
>	id AA26430; Thu, 27 May 93 08:37:56 CDT
>Received: from access.digex.net by max.cecer.army.mil with SMTP id AA22854
>  (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Thu, 27 May 1993 08:37:56 -0500
>Received: by access.digex.net id AA14580
>  (5.65c/IDA-1.4.4 for grassu-list at max.cecer.army.mil); Thu, 27 May 1993 09:37:55 -0400
>Date: Thu, 27 May 1993 09:37:55 -0400
>From: Xin Zhuang <zhuang at access.digex.net>
>Message-Id: <199305271337.AA14580 at access.digex.net>
>Sender: lists-owner at max.cecer.army.mil
>Reply-To: grassu-list at max.cecer.army.mil
>Precedence: Bulk
>Subject: Re:  Please help:r.in.erdas problem
------------------------- End of message header:
