Grass binaries.
James A. Farley
jim at cast.uark.edu
Fri May 28 15:17:08 EDT 1993
Keith,
you need to use the mknod command while logged in as root to create
a named pipe. The general form of the command is:
/usr/etc/mknod filename p
To create the fifo pair 1.a/1.b which would be needed to support
a single grass monitor:
mknod fifo.1a p
mknod fifo.1b p
chmod 666 fifo.1a
chmod 666 fifo.1b
> In referance to the pipes in the dev diectory.
> I brought the 4.1 binaries off the moon and successfully
> unpacked it. It starts fine but will not start a monitor.
> It apparently does not find the fifo's in the grass/dev directory
> and in fact: the directory is empty.
> I seem to recall trying to copy fifo's to no avail before
> and since I am new to unix I ran for the Unix Bible and
> found only terse entries on fifo's. It said they are named
> pipes without saying how to move, render or create them.
> So, what is the answer to this unix cipher?
> Where o where can I get my fifo's from?
> Keith M. Mitchell
> University of Illinois
> Department Of Agronomy
> S 310 Turner Hall
> Urbana, Illinois 61801
> 217 - 333 - 4424
James A. Farley Technical Director, CAST/NCRI-SW
12 Ozark Hall, Univ. of Arkansas
jim at cast.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
