using sites to re-categorise rasters and polygons
Lars Schylberg
larss at fmi.kth.se
Thu Nov 25 02:07:20 EST 1993
> What I have is a raster which has values which correspond to a site list
> for areas corresponding to the thiessen polygons. But, I have a site
> database with 100 attributes, and I want to allocate the various site
> variables to the corresponding raster locations for all of these variables.
You could convert your site list a raster file with that option in s.menu
or with s.to.rast, if your site list is in the format y|x|#attribute.
Then you could run r.stats on the sites_raster_file and
the thiesen_polygon_raster_file to establish the relationship between the
thiessen polygons and the attribute. That can then be piped into r.reclass
via a small awk script that removes the zero categories r.stats list
from the site_raster_file. All this could nicely be handeled in a
little script.
Good luck!
Lars
Lars Schylberg Email: larss at fmi.kth.se
Dept. of Geodesy and Photogrammetry or : lasc at celsiustech.se (new)
Royal Institute of Technology (KTH) Tel. +46 8 790 86 33
S-100 44 STOCKHOLM, SWEDEN Fax. +46 8 790 66 10
