v.in.arc
Olga Waupotitsch
olga at zorro.cecer.army.mil
Fri Nov 26 13:53:24 EST 1993
In info.grass.user you write:
>v.in.arc
>Hallo,
>I am a recent GRASSuser. In our work in Hydrology we have to convert ARC/INFO
>files (watersheds) to GRASS. We are running v.in.arc command with these
>parameters:
>type = polygon
>lines_in = created with UNGENERATE command (ARC/INFO) with option LINE
>points_in = created with UNGENERATE command with option POINT
>text_in = created with UNLOAD command in TABLES (ARC/INFO), which saves a ASCII file containing selected records and items (watersheds categories).
>But the output of v.in.arc (a vector file in GRASS format) does not contain the categories in areas.
>Could anybody help me?. Would it be possible to label automatically these areas
>in GRASS vector file with categories of these areas in ARC/INFO after running
>v.in.arc?
>Juan M. Ruiz
>Centro de Estudios Hidrograficos (CEDEX)
>Paseo Bajo de la Virgen del Puerto 3, planta 3
>28005 Madrid, SPAIN
>Telephone: 335.79.51
>Fax: 335.79.22
>e-mail: jruiz at gea.cedex.es
Can you please ftp the data to moon.cecer.army.mil
user name anonymous
cd to grass/incoming
email me after you are done
Olga
P.S. the best thing would be to tar your whole location.
(with input arc files in arc directory)
