d.mon x0
Bob Harrington
bobh at hwr.arizona.edu
Fri Oct 15 13:46:20 EDT 1993
> WEI, TAI-FEN (t0w6975 at summa.tamu.edu ) writes on 15 Oct 93:
> >is there anyway to change a setup that when i type in d.mon x3
> >the x3 window is in different size and location.
> >kee at harc.edu
> well, sorta (this question just came up recently).
> The environment variables XDRIVER_HEIGHT and
> XDRIVER_WIDTH control the size. If there's a certain
> size that you always prefer, you can put these
> in your ~/.grassrc file. Here's mine:
> GISDBASE: /home/soils/h/mccauley/project/data
> LOCATION_NAME: indiana
> MAPSET: mccauley
> PAINTER: ppm
> DIGITIZER: none
> XDRIVER_HEIGHT: 500
> XDRIVER_WIDTH: 650
> otherwise you can write a shell script to set the size
> and then start the monitor.
> Now, as far as location, I'm not too sure.
> --Darrell
XDRIVER_LEFT 10
XDRIVER_TOP 10
control the placement (in pixel ofset from upper left).
Bob Harrington
