donuts - Vector format flaw!(?)
Malcolm Williamson
malcolm at cast.uark.edu
Tue Oct 19 18:06:59 EDT 1993
Allan Axon writes:
> Using 4.0,
> one problem I have encountered in going from vector to raster is handling
> "donuts" of category 0:
> ____________
> | _____ |
> | |__0__| 1 |
> |____________|
> When rasterized, the above situation, gives
> 1111111111111 11111111111
> 1111111111111 not 11100000111
> There are ways to work around this, but vector maps still have to be
> examined in order to recognize the presence of similar conditions.
> Has this problem already been addressed in 4.1?
Did you run v.support before doing the v.to.rast conversion? Granted, I'm
using 4.1, but these are the results I get:
__________
| _____ |
| |__0__| 1|
|__________|
gives me
111111111
110000111
111111111
*as long as* the attribute point is within the "1" area, not the "0" area. If
the attribute point is within the "0" area, even though I select the outer
polygon as the area boundary, I get:
000000000
001111000
000000000 !!!
This seems pretty reasonable to me, if not terribly convenient!
Malcolm D. Williamson - Research Assistant E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
