Default theshold(s) in v.digit
Brian Culpepper brian at cast.uark.edu
Thu Oct 28 10:50:20 EDT 1993
Morning/Afternoon.....whatever
I would like to know if anyone has ever changed the default snapping
and digitizing thesholds in v.digit? I realize they can be changed
each time one enters v.digit, but ,for instance, if v.digit is re-entered
it resets the thesholds to the default. This is a problem when meta-data
is created for vector files because (v.stats -h) indicates a different
MAP THRESHOLD (in this case greater) than the set threshold at the time
of map creation. I realize this is a small problem, but I think it would
make the lives of the twenty-or-so people who create metadata, much more
enjoyable....
Thank you for listening,
R. Brian Culpepper                                 Research Assistant
Center for Advanced Spatial Technologies           (fax) 501 575-3846
Rm. 214 Ozark Hall                                (work) 501 575-6159
University of Arkansas                            brian at cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
