P.MAP question
    Ronald Thomas
    ront at niwot.CFNR.ColoState.EDU
    Tue Sep  7 09:33:45 EDT 1993
The "legend", such as it is, is a string of boxes equal to the # of
categories in your raster map, with the number (not the text) of the
appropriate category next to it.  You do not need to set a frame.
If you are planning to use p.map output for actual display, you will have
to do some "doctoring" of the legend (manually) .
You might want to look into MAPGEN for hardcopy output if you desire a more
"finished" product.
   Ronald Thomas                         ^  ront at meeker.cfnr.colostate.edu
    Natural Resources Spec. (GIS)        ^
     Resources Management Division       ^   Phone: 303-586-3565  x285
      Rocky Mountain National Park       ^          700-323-7285  (FTS)
       Estes Park, CO  80517             ^   FAX:   303-586-4702
