vector extraction
Paul Loechl
loechl at zorro.cecer.army.mil
Wed Sep 8 13:03:14 EDT 1993
In an E-mail message, Bill Jackson wrote:
> Is there a GRASS4.1 program available for "clipping" a subset of a vector
> file outside of v.digit?
> Occasionally when editing a vector file lines can be unintentionally deleted.
> The cursor can be placed on the line to be deleted and another line. Often
> a larger line segment, nowhere close to the original line, will be highlighted
> instead and can get zapped. Of course, if you are careful this shouldn't happen
> but when it does it is a real hassle, especially on large files.
> Normally, I would make a copy of the original vector file and then edit it with
> the block line delete tool to try to isolate the line or lines that were
> accidentally deleted and then use v.patch to repair the file.
> It would be great to be able to take a subset of a vector file as easily as
> using r.mapcalc map1=map2.
> If there is not a tool available to do this I will try to write a shell.
> Thanks
> Bill Jackson
Try using v.cutter to extract a subset of a vector file. v.cutter allows you to
specify a cookie cutter template such as a boundary line. This cutter template
selects only lines and polygons inside of it. The output is essentially a masked
version of the original vector map. BE SURE to run the v.spag program on the
resultant file to remove any identical lines.
Paul Loechl loechl at zorro.cecer.army.mil
USA CERL (217)352-6511x668
