copying coverages to tape
Ronald Thomas
ront at niwot.CFNR.ColoState.EDU
Tue Sep 14 09:01:37 EDT 1993
Here is one way to do it:
First, change directory "cd" to $LOCATION,
then issue <tar cvf tarfile */filename> where tarfile is either the file
_or_ device where you want to temporarily store the one file, and filename
is the name of your map.
When transfering more than one map, or type (vector & raster) , I create
a new mapset, (called "transfer" or "travel"), then 'g.copy' the maps
layers required into it, and then 'tar' the entire mapset.
If we need to set up a new LOCATION somewhere to do some work, I also 'tar'
the PERMENANT mapset (ours is empty except for the prerequisite default
files) along with the 'travel'ing mapset.
Hope this helps
Ronald Thomas ^ ront at meeker.cfnr.colostate.edu
Natural Resources Spec. (GIS) ^
Resources Management Division ^ Phone: 303-586-3565 x285
Rocky Mountain National Park ^ 700-323-7285 (FTS)
Estes Park, CO 80517 ^ FAX: 303-586-4702
