tcltkgrass/Linux Problem
Cao Changyong
changyoc at daisy.siue.edu
Sat Apr 2 16:06:58 EST 1994
Although I have got the tcltkgrass package running on my Linux Box by
modifying some codes in the TclTkInit.c to avoid a segmenation fault,
I can't help thinking about the problem I avoided. The problem was, in the
TclTkInit.c program, there is a line like this:
tcltkgrass = Tcl_GetVar(interp, "env(TCLTKGRASSBASE)", GLOBAL_ONLY);
The "env(TCLTKGRASSBASE)" causes a segmentation fault at run time. I
thought that "env" belongs to the ksh, therefore, I invoked the ksh. Then
I got a memory fault.
I know env is in the manual page therefore I assume it is available in
my Linux box. I can't figure out what causes the segmentation fault.
Any suggestion?
Thank you.
Changyong Cao
