XDRIVER problems on HP 9000/710
Peter Mikes
mikes at angmar.llnl.gov
Mon Apr 11 12:48:01 EDT 1994
The question (of the compile FAQ type) was :
I get message : ./includes.h: 9: Can't find include file X11/Xos.h, when compiling an X application.
The answer is:
In the header file, created by the initial questionare, you did not give location of your
X includes . (this is apparent from the cc line you gice, namely
cc -D_NO_PROTO -I/npi/grass4.1/source/src/include -DUSE_TERMIO -c SWITCHER.c )
To correct this, you may 1) find location of your X-includes
2) edit your header file to point to them
re 1)
oberon 21: fastfind X11/Xos.h
/usr/include/X11R4/X11/Xos.h
/usr/contrib/mitX11R5/include/X11/Xos.h
oberon 22:
shows have two posibilities in this HP machine, I pick one :/usr/include/
re 2)
Go to your header file in directory $GRASS_HOME//src/CMD/head and edit line which starts as
XINCPATH = -I/usr/openwin/share/include
to point to your X-includes, in exapmple above I would make it to be :
XINCPATH = -I/usr/contrib/mitX11R5/include
then restart compilation process
