non-interact. d.3d
    Malcolm Williamson
    malcolm at cast.uark.edu
    Mon Apr 11 15:56:57 EDT 1994
Is 700S really a valid coordinate here? I assume that you're working in
lat/long.
> Hi everyone,
> I've encountered some difficult to use d.3d in non-interactive mode (command line).
> I tried before with the spearfish DB e default parameters: all goes well :-).Few minutes
> later I'tried with my DB (that work normally well, it is a cdrom of the WORLD BANK!),
> and there is no way to work :-(( !
> There is ever the error:
> -->> WARNING: G_set_window(): Illegal latitude for North
> -->> ERROR: Inappropriate window resolution request
> belowe a list of some attempt.
> Thanks in advance for any suggestion.
> PS : in interactive mode all works well :-() !!!!
> 							--FRY
> d.3d -0a map=nations. elevation=aspect. from_coordinate=105E,2N,15
> to_coordinate=150W,700S,700
> Mapset <PERMANENT> in Location <cdrom>
> GRASS 4.1 > d.3d -0a map=nations. elevation=aspect. from_coordinate=-105W,2S,15
> GRASS 4.1 > d.3d -0a map=nations. elevation=aspect. from_coordinate=2S,-105W,15
> to_coordinate=700S,150W,700
> GRASS 4.1 >  d.3d -0a map=nations. elevation=aspect. from_coordinate=150W,700S,700
> to_coordinate=-105W,2S,15
> GRASS 4.1 > d.3d -0a map=nations. elevation=aspect. from_coordinate=700S,150W,700
> to_coordinate=2S,-105W,15
> and so on in all coordinate format.
> Davide Frisoni                      |  e-mail(internet):
> Forschungsinstitut fuer anwendungs- |  frisoni at faw.uni-ulm.de
> orientierte Wissensverarbeitung FAW |
> Helmholzstr. 16                     |  Tel.:  +49-731-501 8626
> D-89081 Ulm, Germany                |  FAX:   +49-731-501 999
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
