Removing unwanted nodes
Melissa Cowoski
cowoski at pangea.Stanford.EDU
Fri Apr 15 15:46:45 EDT 1994
I want to create a vector file from a raster. I scanned in a map with
lines marking different vegetation units. I brought it into GRASS and
reclassified the map into two categories 1=line 0=no line. I then used
r.thin to thin the lines to one pixel. Afterwards, I ran r.line and chose
areas. It created a vector file containing polygons made up of several
lines with their corresponding nodes. I want to remove the nodes in order
to have one line surrounding each area. The GRASS manual suggested I use
v.trim however it didn't improve the situation. I looked in v.digit but I
didn't see anything that would work. Any suggestions???
Melissa Cowoski
Stanford University
cowoski at pangea.stanford.edu
