r.buffer problem/musing
    Simon Cox
    simon at artemis.earth.monash.edu.au
    Sat Apr 16 11:04:35 EDT 1994
I disagree with your objections.
If you tried to buffer each separately, then a variety of
possibilities exist for how to classify areas which fall
within the buffers of two different types.  Going through the
multiple procedure you suggest, finishing with mapcalc, is probably the
best way to cover all the possibilities in that.
Don't worry about all the extra files that are created - reclass files
don't take much space.
If you find it tedious, I think that this is probably the time to learn
how to write scripts ;-)
Simon Cox
