d.rast.zoom2 script
    Rick Thompson
    rick at cast.uark.edu
    Thu Apr 21 12:24:45 EDT 1994
GRASS users,
  This script may be useful to you for specialized zooming in and out of data;
I found it useful for visually checking imagery in GRASS.
----------------------------- Cut Here ---------------------------------------
# *** d.rast.zoom2 ***
# Written by Rick Thompson
# @(#) d.rast.zoom2: allows repetitive display and interactive d.zooming of up
# @(#)               to 1 raster map, 1 raster overlay map, and 2 vector files,
# @(#)		     plus d.zooming back out in the reverse order. Additionally,
# @(#)		     a region can be saved, the original raster file's region
# @(#)		     can be returned to, or the user can do a one-time display
# @(#)		     of a new raster or vector file.
# @(#) Last revision: 4/20/94
ARCH=`uname -m`
if [ $ARCH = mips ] ; then
  ECHON="/usr/bsd43/bin/echo -n"
 else
  ECHON="echo -n"
fi
if [ "$GISRC" = "" ] ; then
  clear
  echo "This command must be run from GRASS!"
  echo ''
  exit 1
fi
name=''
clear
echo ''
resp="n"
until [ "$resp" = "y" ] ; do
g.ask type=mapset prompt="Please select a raster map:" element=cell desc=raster unixfile=/tmp/$$
  . /tmp/$$
rm -f /tmp/$$
if [ ! -f $LOCATION/cell/$name ]; then
  echo "Raster map $name not found in mapset $MAPSET."
  resp="n"
  echo ''
else
  rast="$name"
  name=''
  resp="y"
fi
done
echo ''
resp="n"
  $ECHON "Do you want to specify a raster overlay map, too? (y/n) "
  read ans
  if [ "$ans" = "y" -o "$ans" = "Y" ] ; then
    echo ''
    g.ask type=mapset prompt="Please select an overlay raster map:" element=cell desc=raster unixfile=/tmp/$$
    . /tmp/$$
    rm -f /tmp/$$
      echo "Overlay raster map $name not found in mapset $MAPSET."
      resp="n"
      echo ''
    else
      overlay="$name"
      name=''
      resp="y"
    fi
  else
    break
  fi
done
echo ''
$ECHON "Would you like to display a vector map? (y/n) "
read ans
  echo ''
  g.ask type=mapset prompt="Which vector map?" element=dig desc=vector unixfile=/tmp/$$
  . /tmp/$$
  rm -f /tmp/$$
  if [ ! -f $LOCATION/dig/$name ]; then
    echo "Vector map $name not found in mapset $MAPSET."
    resp="n"
    echo ''
  else
    vect="$name"
    name=''
    resp="y"
    $ECHON "What color should be assigned to $vect? "
    read col
  fi
else
  break
fi
if [ -n "$vect" ] ; then
  echo ''
  $ECHON "Would you like to display a 2nd vector map (y/n)? "
  read ans
    echo ''
    . /tmp/$$
    rm -f /tmp/$$
      resp="n"
      echo ''
    else
      vect2="$name"
      name=''
      resp="y"
      read col2
    fi
  else
    break
  fi
fi
g.region rast="$rast"
res=`g.region -g | grep nsres | cut -d"=" -f2 | tr -d ' '`
d.erase
d.rast "$rast"
if [ -f $LOCATION/cell/"$overlay" ] ; then
  d.rast -o "$overlay"
fi
  d.vect "$vect" c=$col
fi
if [ -n "$vect2" ] ; then
  d.vect "$vect2" c=$col2
fi
g.region save=rastzoomtmp1
response="y"
i=1
until [ "$response" = "n" -o "$response" = "N" ] ; do
  clear
  echo ''
  echo "Please select one of these actions to:"
  echo ''
  echo "1 - use the interactive d.zoom"
  echo "2 - go to the previous zoom"
  echo "3 - go to a designated region"
  echo "4 - return to $rast""'s"" region"
  echo "5 - save the current region"
  echo "6 - do a one time display of a new raster map"
  echo "7 - do a one time display of a new vector map"
  echo "8 - quit"
  echo ''
  $ECHON "Please enter the appropriate number: "
  read number
  case $number in
	1) i=`expr $i + 1`
	   d.zoom -q
	   g.region save=rastzoomtmp$i
	   d.erase
	   d.rast "$rast"
	   fi
	   fi
	   fi;;
	2) i=`expr $i - 1`
	   if [ $i = 0 ] ; then
	     echo "No previous zooming windows remain. Would you like to view"
	     $ECHON "the default region? (y/n) "
	     read ans
	       g.region -d res=$res
	       d.erase
	       d.rast "$rast"
	       fi
	     fi
	     fi
	     if [ -f "$vect2" ] ; then
	     fi
	   elif [ $i -lt 0 ] ; then
	     echo ''
	     echo "No previous zooming windows remain."
	     echo ''
	     sleep 3
	   else
	     g.region region=rastzoomtmp$i
	     d.erase
	     d.rast "$rast"
	     fi
	     fi
	     fi
	   fi;;
	3) echo ''
 	   echo 'The region is based on:'
	   echo ''
	   echo '1 - raster file'
	   echo '2 - vector file'
	   echo '3 - region file'
	   echo ''
	   $ECHON 'Please enter the appropriate number: '
 	   read regno
	   case $regno in
		1) echo ''
		   type="rast";;
		2) echo ''
		   type="vect";;
		3) echo ''
		   type="region";;
	   esac
	   g.list "$type"
 	   echo ''
	   $ECHON "Enter the $type region you want: "
	   read newreg
	   g.region "$type"="$newreg"
	   d.erase
	   d.rast "$rast"
	   fi
	   fi
	   fi;;
	4) g.region rast="$rast"
	   d.erase
	   d.rast "$rast"
	   fi
	   fi
	   fi;;
	5) echo ''
	   $ECHON "Enter the name by which to save this region: "
	   read nreg
	   g.region save=$nreg;;
	6) echo ''
	   g.ask type=mapset prompt="Please select the tmp raster map:" element=cell desc=raster unixfile=/tmp/$$
	     . /tmp/$$
	   rm -f /tmp/$$
	     resp="n"
	     echo ''
	   else
	     rname="$name"
	     name=''
	     d.rast -o "$rname"
	   fi;;
	7) echo ''
	   g.ask type=mapset prompt="Please select the tmp vector map:" element=dig desc=vector unixfile=/tmp/$$
	     . /tmp/$$
	   rm -f /tmp/$$
	     echo ''
	   else
	     vname="$name"
	     name=''
	     echo ''
    	     echo -n "Enter $vname""'s"" color: "
     	     read vnamcol
	     d.vect "$vname" c=$vnamcol
	   fi;;
	8) rm $LOCATION/windows/rastzoomtmp*
	   exit 0;;
esac
done
Rick Thompson-   Research Assistant           E-mail: rick at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-5736
Ozark Hall Rm. 12                             Fax: 575-3846
University of Arkansas
Fayetteville, AR 72701
