No subject
    ront at yuma.ACNS.ColoState.EDU
    Thu Apr 28 10:54:17 EDT 1994
In article <2pnp53$d9a at wega.rz.uni-ulm.de> frisoni at faw.uni-ulm.de
(Davide Frisoni) writes:  (edited)
>Normally there are no problem, but ....
>.....                    in one I had a core dump (Great Britain).
>I've analyzed results and I discovered :
>- core dump was verified in this case
>                             |end poly
>                             v
>               ____          ____
>		   |________|
>			    |start poly
>- other cases are similar situations or 90 degree wise.
>The same result I had with or without smoothing !
>                                                --FRY
Just want to add that we've had many core dumps of r.poly using a SOLARIS
2.x/gcc compiled version of GRASS4.1 with all updates.  Works fine on
SMALL coverages, but if I attempt to do vectorize anything extensive, I get
dumped out.
Also, on the problems that have been mentioned about v.trim:  I've given up
considering it to be a viable tool, because of it has consistantly given
bizarre results (missing islands, line features looping back and connecting
to the beginning node over new paths , etc.).  This has occured over various
versions of GRASS.
Ronald Thomas                                ront at meeker.cfnr.colostate.edu
 Natural Resource Spec. (GIS)         ^^^    Phone: 303-586-1285
  Resources Management Division  ^^  ^^^^^   FAX: 303-586-1310
   Rocky Mountain National Park ^^^ ^^^^^^^  Estes Park, CO  80517
