Global data set not working
Jim Pirzyk pirzyk at cerl.cecer.army.mil
Thu Aug 11 15:55:17 EDT 1994
In info.grass.user you write:
>Netters,
>	I finally installed all tutor data set came with GRASS onto
>	my tiny Linux box.  Everything is fine except the COASTLINES
>	vector file can not be opened.  The res. of that file is
>	a big negative integer.  I suspected that is the reason why
>	the file can not be opened.  Any suggestion?  Thanks!
I have found out that the coastlines vector file is in an old grass
vector format.  There is a file on moon:/grass/incoming/coastlines.new
that is in the proper format.
- Jim Pirzyk
[Jim] pirzyk at uiuc.edu -------------------------------------------      __o
TAC & GrassNet System Administrator, US Army Corps of Engineers      _'\<,_
Construction Engineering Research Laboratories, Champaign IL USA    (*)/ (*)
