how do i read documents
Gigi Horsefield
GHORSFIE at sog1.geog.ox.ac.uk
Wed Aug 17 11:33:00 EDT 1994
Date: Fri, 5 Aug 1994 09:16:38 +0200 (MET DST)
Reply-to: Cosyn Bart <Bart.Cosyn at rug.ac.be>
Subject: Re: how do i read documents
Reply-to: grassu-list at max.cecer.army.mil
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To: Rica Saporta <saporta at smokey.forestry.utoronto.ca>
Cc: Grass users <grassu-list at max.cecer.army.mil>
On Thu, 4 Aug 1994, Rica Saporta wrote:
Dear,
> also, we know that we can print out postscript files, but how do we
edit
> them?
In addition to Giacomelli's mail I inform you you can find
text-processing and viewing software in the anonymous site:
ftp.sunet.se
in subdirectory /pub/text-processing/postscript
Bart
Ir. Bart Cosyn
Laboratory of Hydrology & Watermanagement
Fac. of Agricultural Sciences and Applied Biological Sciences
University of Gent
Coupure Links 653
B-9000 Gent
Belgium
Tel +/32/9/264/61/37
Fax +/32/9/264/62/36
E_mail:Bart.Cosyn at rug.ac.be | or bcosyn at allserv.rug.ac.be
From: Andrea Giacomelli <andreag at idra1.iar.polimi.it>
Precedence: Bulk
To: grassu-list at max.cecer.army.mil
Date: Fri, 5 Aug 94 9:00:36 METDST
use 'uncompress'
edit
> them?
As you may observe fromt the discussions on the list, this is a BIG
problem.
In 99% of the cases, you may preview your file with some packages
(ghostview for instance), but editing is something you should usually
do
before creating a ps file
Cheers,
Andrea Giacomelli
DIIAR Politecnico di
Milano, Italia
Date: Fri, 5 Aug 1994 07:53:32 -0400 (EDT)
From: "Brad Robbins (BIO)" <brobbins at chuma.cas.usf.edu>
Precedence: Bulk
Cc: grassu-list at max.cecer.army.mil
There are several "zipping" packages available that will uncompress
your
files. Try an "unzip" or "gunzip" command.
I found that you can edit postscript files using UNIX's vi editor. The
problem is reading the script. It will take awhile but after spending
some
time you'll begin to make some sense out of the PS gibberish. At the
start of each page is a header listing the page numbers of the
previous
and next page. Use these as guides to move around in the
document.
Good luck,
Brad Robbins
