No subject
kilee at CC.UManitoba.CA
Fri Aug 19 11:29:28 EDT 1994
Dear GRASSusers ,
I have a question about v.to.rast using v.digit.
At the following menu, are all lines converted into Area edges ?
Is right ?
GRASS-DIGIT Version 4.10 Main menu |
| MAP INFORMATION | AMOUNT DIGITIZED |
| Name: miner.dxf | # Lines: 0 |
| Scale: 2400 | # Area edges: 232 |
| Person: kilee | # Sites: 0 |
| Dig. Thresh.: 0.0300 in. | - - - - - - - - - - - - - -|
| Map Thresh.: 1.8288 meters | Total points: 1388 |
| OPTIONS: |
However, at Label areas command in v.digit, " Areas is not defined message"
is shown, and labelling always failed. What the problem in this process ?
My purpose of this procedure is to convert vector( with several areas )-based file
to raster-based file, and original vector file was digitized from dxf format of Autocad.
Looking for advice.
Thanks in advance.
Kiwon
