g.setproj
Irina Kosinovsky
irina at diego.cecer.army.mil
Mon Aug 29 11:36:49 EDT 1994
In info.grass.user you write:
>Can someone explain how g.setproj works. According to the man page, it
>should prompt for the projection. In practice howver, it seems to read
>the proj from DEFAULT_WIND. The problem I'm finding is that the only
>valid proj: values are:
> 0:(xy)
> 1:(utm)
> 2:(state plane)
> 3:(ll)
>and g.setproj doesn't like anything else. So how do I get nifty
>projections like aea,lcc,merc,tmerc? Note this is the same list that
>comes up for me when making a new location. Shouldn't that include all these
>projections?
>Thanks in advance.
>Quinn Hart (qjhart at ucdavis.edu)
>Dept. Land, Air, and Water Resources
>UC Davis
I think if you select "Other" (i.e. 99) when creating a new location,
g.setproj will ask you for a projection name other than those 4
Irina
__| \ / |__
_ o ___\o \o | o/ o/___ o _
/\ /) | ( \ /o\ / ) | (\ /\
___|_\______irina at zorro.cecer.army.mil_____/_|__
